1 - 12 of 12 Posts
Hey guys!
When stationary I am getting fumes inside the car.
I thought it was exhaust fumes, but I had an exhaust place check it out and there are no leaks.
Any ideas :?:
This dose not sound safe , is oil getting on something hot in the engine bay and then making it's way via the HEVAC ?
I once had a Defender that sucked in exhaust fumes and put me to sleep by the road end , I was driving. :shock:
Dose it go away if you hit the air recirculation button?
Eventually got to the bottom of this problem.
Turned out to be a short breather pipe from the sump that had split.
Part number is LLH000110 - £2.82.
RESULT! :thumb:
£2.82! that will probably never happen again :thumb:
I am also having this problem for the past few weeks now..... when I come to a complete stop or backing up slowly, I get the exhaust smell. My muffler is also in perfect shape. Can you give me a idea where to look in the engine bay for the pipe.
Thank you
Agreed- the vent pipe and the pipes that attach to it - common failure.
Mine didn't fail by fumes coming into the cabin ... I put the foot down for an overtake and the large pipes to the seperator split venting the oily sludge onto the exhausts and a huuuuge trail of white smoke poured from the car as I went past the cars.
I looked in the mirror to pull back in and **** near keeched ma'sel on seeing the smoke. Thought i'd truly blown the engine. :lol:
The missus wasn't overly happy either. oops.
garioch43 said:
Hi Herman,
My local specialist garage sorted it for me.
It is described as....
Crankcase Vent Oil Separator to Drain Vent.
http://www.roverparts.com/Parts/LLH000110G.cfm
Your symptoms are EXACTLY the same as mine, so i'm sure this will fix it. :pray:
Good luck!
thanks for taking the time to reply. I will try to have a look soon, I will update with what I find.
You might want to stop at the local airport and get Carbon Monoxide detector for a small plane, which will tell you if you have that problem.
1 - 12 of 12 Posts
