I have a 2012 sport supercharged. I am getting low rail pressure codes when standing on the gas. I have a new sensor to install. It is supposedly buried at the firewall on the end of the passenger fuel rail. I can’t even see it from up top. Can anyone explain how to access this for replacement?
I have searched all over the internet and can not find a procedure for replacing this sensor. If I had to guess, it looks like you may have to remove the battery and battery box. The engine compartment fuse box is located in the battery box so I really want to know for sure before I just start removing things.
Has anyone replace this sensor ?
well I finally figured out how to change this sensor. Remove the battery and the inside half of the battery box and the sensor is sitting right there. I have searched online and in various publications and forums and never found a straight answer.
2011 range rover sport
