Hello again, next problem: RR is sitting outside, no problems since last service, it was enjoying a little sun we hadn't seen for the past few weeks and when needed to start, it would just not start. No fault message, RR would open with remote key, RR cranks, battery is fine. When cranking, I had someone to hit the fuel tank with his hand a couple of times and suddenly RR would start?? Would this mean we need to get the fuel pump changed? Fuel tank was just above a 1/4 full,... I've heard about a second pump which would be sitting in the tank which transfers fuel from one side to the other? is it easy to have it changed if its this one who's failing? Should both pumps need to be replaced? Anyone who has had this problem and had fixed it could give me a hand?? Many thanks for your help. Kind regards, Michael
