I have a 2007 RR HSE 4.4 and am in the process of changing the front wheel hubs and bearings. Looking online I am not having much luck locating the assembly as unit. Does anyone know of remanufactured or refurbished assemblies for this model year?
The hub itself looks to be part LR009816 but again, I would prefer to find the assembly so i can remove the old hardware and place the new setup in.
Thanks for the advice in advance.
I believe Atlantic British has them, but why do you need to replace? Unlike the LR3/sport, you can't just unbolt the hub and throw a new one on (with new bearings). You will need to pull the whole spindle/hub assy out, and have a shop press the new bearings in. I had my indy shop press the bearing for $20. You need RUH100030 (hub nut), RLB000011 (Bearing), & RUE000010 (snap ring). I decided to do both sides when the passenger side failed @ 101k. The failure was in part due to a hub nut that wasn't torqued properly during the previous repair.
