Range Rover Sport MY 2009 with 35000 miles
Heard a metal to metal loud clunk noise from front left area when turning and at low speeds.
Had initially both lower control arms replaced,then both sway bar links replaced at local independent land rover specialists shop.
Upper arm bushings and sway bar bushings look OK.
Now I get annoying knock/Pop noise at low speeds below 35 MPH.
This only happens when the car warms up after driving a few miles.
Any ideas on what is going on?
Thank you
David in Washington DC
I had the same noise also at low speeds. Here's what was replaced highlighted in yellow. Hope this helps.
