I have a 2006 rrsc and the front passenger door wont open from either side. I have been opening it from the inside for some time now and now it wont open from the inside anymore. Is there anyway i can get it open so i can figure out what is going on in the under the door card. I cant get the door open to check it.
As far as I know the door card can be removed even with the door closed.
Adjust the seat down and back as far as it will go to get easier access. I think there is just one screw which remains obstructed by the seat but a stubby screw driver should do the trick.
Another thing that might help is removing the rear passenger door. This gives you access to the screw (in the front door) that holds the outside handle in place. Removing the handle and its back plate might give you access to the part of the mechanism that is causing the problem.
