probably time to replace the front end bushings - search on bushings and/or control arm and you'll see similar stories. good luck
I don't think his issue has anything to do with a leaking strut, when those leak it's obvious and they don't usually make a cracking noise when you're turning the wheel.RR Family said:I replaced my front end bushings too, but the problem you have sounds like a weak/leaking front air shock to me. I had the problem when I would come to a stop, then accelerate when turning through a dip or a bump, it made that noise. Turned out the shock was losing pressure over bumps and not reapplying pressure soon enough to keep the tire from slipping. Have someone stand outside and see if that is what yours is doing.
