So I just spent another hour and a half removing the rest of the grill, wheel well inserts, total front bumper, and disconnecting the windshield washer lines and the radar/sensor and camera wiring for a total of 2.5 hours labor the last 2 days. By far, the most miserable part of this process was/is removing/disconnecting the driver's side main wiring harness located right next to the condensor... I couldn't get that
[email protected]$tard apart like I've never seen. My back and abs went into spasm an hour ago due to being contorted in the drivers wheel well for almost an hour in the August 90+ degree heat just on that one component. I rewatched the particular part on how they disconnected that Wiring Harness on the YouTube L405 video 4 times. They say there is a button/tab to press and disconnect it and so so in about 5 seconds. Nope, no such animal, button, or releasing tab on the14.5' L494. And this is far from my first time doing this with electronics, wiring harnesses and sensors for a wide variety of vehicles and manufacturers. But, it along with the smaller grey and beige sensors are finally disconnected and tied up and safely out of the way now.
While I'm at it replacing both Cameras tomorrow I'm going to wash, prep and refresh the Grill in Gloss Black (has 3 or 4 chips) as well as redo the front tow hitch cover in a matching Gloss Black of which I've been meaning to do anyways. Since I'll be headed to Land Rover North Atlanta tomorrow for new crystal clear cameras I'll pick up another 8 quarts of Castrol Professional and an JLR filter for the next oil change within the next 1,000-1,500 miles. I use the 5 cameras far more than I thought I ever would being that I park in a narrow parking deck with stupidly high concrete curbing at both the exit and entry points.
Most if not ALL of us DIY guys on this wonderful Community Forum can do the camera repair/swap as well as the front adaptive cruise sensors. Just budget a full 3 plus hours and start your repairs in the morning instead of at 3:30pm in a Georgia August heat like I elected to do. I also recommend taking the drivers side front wheel off and using a jack stand and back up floor jack on the frame as so you can have all the room you need so you aren't in a contorted and muscle pulled state like I am right now. I'm quite limber and I'm sitting on ice right now. Just an PSA to all of us that are 40 years old and older here, hahahaha!
Pic of front gloss black grill and matching fogs painted when I first got her. I also redid the lettering front and rear in gloss black myself as well the first week I got her back in November. The Tow hitch cover plate will go from Grey to a matching Gloss Black tomorrow as I've been meaning to match her up for a while now... A minimum of 4 coats for durability and a flexing agent mixed in the paint I've yet to decide upon as to combat chips and flaking from road debris, grime and all the crap semi's, box trucks, cement and dump trucks spew rolling down the highways...
@DieselD I have a few tips for you bro for when you want to replace your front cameras bro so don't hesitate to reach out as I'll walk you thru the nuances as to make your life and back pain free!
