Hi all,
I ran out of CPO warranty back in June 2009. I think my front air suspension is leaking as I will lower my truck into the ride access height (lowest setting), park the truck and let it sit for a few days, then when I come back to start the vehicle (after sitting for a few days) it is sitting even lower almost to the bumper stops. Then, I will sit in the vehicle and turn the key to the first stage without starting the car --- at this time the vehicle will make its correction of the air suspension for the front left and right and the compressor will give both front and left side fronts a "blast" to pump them up to the ride access height.
The obvious question is: are they leaking? If yes, do they need to be replaced?
The air suspension seems to not noticeably leak overnight as I have tried my test sequence (written above) and the vehicle does not give the slightest hint of a compressor "correction" blast of air.
Lastly, if they do need to be replaced, I am concerned that I brought my vehicle in to LR while under warranty at least 3 times for my suspicion that the air suspension on the front has been leaking. All three times I was turned away (less $150 every visit).
Thoughts on if I there is any recourse here?
Thanks in advance!
-spizzi
Thanks in advance!
-spizzi
