So I've been slowly getting the EAS in working order over the past few months and finally thought I had it roadworthy. I now have leak free airsprings, new o-rings at each airspring and a rebuilt valve block. I was able to get the system pressurized and bring everything up to normal ride height successfully.
When I start the vehicle, it now almost immediately goes into a soft fault. I read the fault using the EAS software from RSW solutions, and it gave 'FR incorrect signal'. I pulled both front sensors and put an ohmmeter on them and their values were nearly identical reading across the entire resistor or from the wiper to the other pins. I also slowly swept the arm and made sure the values changed smoothly - everything was fine for both sensors. For good measure I swapped them during reassembly, unlocked the EAS using the software and fired it up. Almost immediately I got a soft fault. I read the faults and once again got 'FR incorrect signal'. I understand that I may have a wiring issue to the front right sensor or it may possibly be a faulty valve block driver unit as I have heard that can be the cause of lots of frustrations.
With the EAS software, I am able to raise and lower each airspring no problem, including the front right corner in question.
My question is, what voltage/values should I see if I were to test at the height sensor connector while the system is running? Is there a constant voltage at one of the pins etc? I feel like I am so close to getting this finished and working.
Any advice is greatly appreciated..
