Forgot to tighten the coolant cap> coolant spilled any problems???
I checked my coolant level at home and forgot to tightened the cap so I drove to work and when I arrived I noticed the smell of coolant so I opened the hood to check it and thats when I noticed the cap was loose and the coolant was spilling. Could that have caused any major problems? Also can I refill it with water meanwhile? What kind of coolant can I use besides the one sold at the dealership? It's an 2003 BMW Engine
Re: Forgot to tighten the coolant cap> coolant spilled any problems???
No worries, rinse with water to avoid coolant to dry out,
it will make stains and corrosion if not.
You can refill with water, but I´ll recomend to use coolant. I guess your coolant is pink,
so use pink coolant.
the BMW coolant is dark Blue
Go o the supermarket and buy a gallon of distilled water
then top up the system with that
