1 - 15 of 15 Posts
2002 P38 4.6 HSE
What was this foam filter/screen under this grill for, and how important is it? What do i ask for and where would I find them? It requires 2 of them. I just don't like the way it looks ragged.[attachment=1:2dhgckrl]Filter 1.jpg[/attachment:2dhgckrl][attachment=0:2dhgckrl]Filter 2.jpg[/attachment:2dhgckrl]
http://rangerovers.net/newrremedies.htm#airconditioning
Air Intake Filter: There is a long piece of foam filter under the panel in front of the windscreen, and after a while it decays and gets pushed out of position by the air flow. FItting a new one is not too difficult, but Robert Watson found a cheaper solution. He reports "I have just used black pond filter foam to replace the rotted foam HVAC external filter in the plastic plenum cover below the windscreen. Lots of different filter material could be employed and presumably keeping this effective will reduce the load on the pollen filters".
RIP Our Friend
There is one, it's long and it keeps needles and leaves out of your A/C system. The panel is easy to pull off, hopefully the retaining wire isn't rusted in place and the filter material can be bout at pond supply stores.
2002 P38 4.6 HSE
Thank you all very much. Off to the pet store this week. Let you all know how it works.
Consider for a moment where all the missing foam from the old plenum filter went.
I used fly screen wire on mine a couple of years ago and it still looks like new. Sure, it only stops the stuff bigger than a small insect but I change the Pollen Filters regularly on service and it has been very successful.
green_rangie said:
Consider for a moment where all the missing foam from the old plenum filter went..
It could blow into the engine bay.
Thanks Ron. Maybe I am missing something, when I read Rave I thought it could end up in the ventilation air intake:
'Fresh air is drawn through the grille at the base of the windscreen and into the plenum, from where it passes through pollen filters into the air inlet housings.'
Yes, that's correct.
See the second pic above, I've always wondered about the purpose of the lower vents to each side of the intake area. They look like they feed into the engine bay. I don't think they do as the rubber bonnet seal would stop it.
They have no foam across them and I've no idea as to their purpose.
there's a member named 996turbo over in france who did this with aftermarket material and it looks real sharp. he knows what he's doing. i have to get around to that and some other things (see my nagging injuries thread) but i'm not going to use oem filter only to have it disintegrate later. please post pics along the way if you DIY.
RIP Our Friend
The DIY is no different from RAVE. Only the sturdy pond filter material has changed to save labour later.
so you're saying i can use the existing hardware in there (the skeleton isn't rusty, it just resembles the mast of a pirate ship) and attach filter medium with it?
2002 P38 4.6 HSE
Discussion Starter · #14 ·
msq17 said:
Thanks for bringing this up, BigMack. I too have wondered the same thing but I always forgot to look into it.
No worries. It's my job to ask. LMAO! I really like the "Screen Door / Fly Screen" approach. I think it would look nicer.
Temecula. Just visited my sister up there Sunday.
1 - 15 of 15 Posts
