A few days ago my radio stopped producing any FM stations, and as it seems even receiving any FM stations at all.
The AM, navigation and CDs work fine, so it seems everything else is working.
That led me to the antenna circuit as the first thing I suspect.
Looking at RAVE, the best I can tell is that there is an amp (pictured) between the antenna (back window heater element), and I looked at the 3 wires going to it.
There's a red with a black stripe,and white with yellow stripe, and a white.
I can't find much info in RAVE for the wires to or from the antenna amp, but as far as I can find, the white wire is power.
Does anyone know or is able to find where the wires to and from the FM amp connect?
At the white wire read about 0.6 volts, but not sure since I can't find what the return line is.
If you can tell what the return line is and what the supply voltage is, it could help me figure out if the amp is bad or not.
Has anyone got any suggestions or experience with FM-only radio problems?
Thanks for the help!
