After reading around of the net its clear that alot people are clueless about their Classic and cant get the right information. So here is the basic need to know stuff for you Range Rover Classic that was built past 1989. All units of measure are USA liquid.
Engine: The NAS (North American Spec.) Range Rover Classic came with either a 3.9l V8 or a 4.2l V8. Its a alloy block V8. A very rugged design that can take lots of abuse but is very sensitive to overheating. So its very important to keep the propper coolant in the engine as well as checking the level atleast once a week. The propper coolant is ethylene glycol (green kind), the system holds 3gals. The Rover V8 is also sensitive to oil. Changing your oil every 3,000miles is very important. A high zinc oil, low detergant oil is key to long engine life. Many owers prefer 20w50 in the summer and 10w40 in the winter. A good quality oil filter is a must. The eninges slump capacity is 7qts.
Myth: The Rover V8 is the same as a Mustang 4.6 engine. False the 4.6 Mustang engine is not a Rover V8, they are totally different engines.
Brakes: All 1990 and newer Range Rovers have a very well engineered braking system. A important thing to remember is that the brake system uses DOT4 brake fluid. Fluid should be changed every time you put on fresh brake pads.
Axels: The axels used on the Range Rover Classic are very strong and will suit all of your off-roading needs. There are axel shaft upgrades and gear upgrades avalible but for must owners the factory axels provide plenty of strength. The Classic used a swival style axel in the front to steer. The swival housings are filled from a different plug than the diff. The swivals hold 1pt each and the diffs take 1.5qts each. Land Rover says to use a 80EP gear oil. 80w90 will work as well.
Tranfercase: The most common mistake made on the Classic at service is filling the transfer case with gear oil. The transfercase uses Dextron II transmission fluid. Its capacity is 2qts.
Transmission: The automatic transmission uses Dextron II. A very well made and engineered transmission that will provide you with many years of enjoyment as long as propper fluid/filter changes are done every 30000miles. The capacity is 10qts from dry. Figure 7-8qts are needed for a filter change. The cross-member has to be removed to drop the pan.
Power steering: The power steering system on the Classic is a common leak point. Many owners have had good luck with Lucas stop leak in their systems. The propper fill for the Classic's power steering is Dextron II.
When you buy your used Range Rover Classic the first thing you should do is a complete fluid change. Its your cheapest insurance against major failures. When having your Range Rover serviced anywhere besides a Land Rover dealership print this out and give it to the tech. 9 out of 10 times a service center will use the wrong fluids and cause a major failure.
FOUNDING MEMBER
Couple of comments: 1) 87 & 88 RRs came with a 3.5L v8. The 3.9 didnt come out until 89 2) 87 & 88 RRs have the LT230 t-box which uses 80-90 weight gear oil, not Dexron II transmission fluid.
http://www.rangerovers.net/rrbuying.htm
My info is for 89' plus models
I think they stopped making dex 2 so instead of looking all over for it use dex 3, it is its replacement.
FOUNDING MEMBER
Yep, you are right. 2nd sentence...I missed it.
I want to do another section for 88' and before but I lack the resources to do so.
I think this post should be a sticky at the top of the forum. Many of us forget this information and putting it on top would be a big plus. :dance:
Parker
1993 LWB Plymouth Blue
FOUNDING MEMBER
Here you go
[attachment=1:10185t91]Lubricants Fluids and Capacities RRC.jpg[/attachment:10185t91]
[attachment=0:10185t91]Lubricants Fluids and Capacities RRC 2.jpg[/attachment:10185t91]
