G
Guest
I did some searching and found one thread, but it didn't have actual suggestions. So, which ones do you guys use/recommend? There was a post that mentioned that we need something that lifts up to at least 20"... that greatly limits the choices (affordable choices at least). I had a crappy torin suv jack, worked fine but just gave way. Would a jack that lifts about 18" high be adequate?
Thanks...
I think 18" works for near stock tire diameters. ~29" I believe.
I want to say mine is ~16" and it works for stock, but just not the off road rubber.
SUPER MODERATOR
The standard 2.5 ton floor jack from Sears (Craftsman) does the trick just fine for street or offroad tires.
