Hi all
I read somewhere on rangerover.net about fitting front fog lights,It says you shouldnt fit foggers on a diesel automatic.Is this true?
has anyone done it and experienced problems?What problems are there?
hope you can help.
cheers
· RIP Our Friend
The only issue is moving the tranny cooler or replacing it with an aftermarket unit. Once you have made your choice on that topic the light units bolt right in and the wiring is a breeze.
2000p38 said:
Hi all
hope you can help.
cheers
You also need to get them turned on in the BECM. As rrtoadhall said, the wiring is a breeze, its all plug and play, even the switch in the dash. I wired flashing LED hazard lights for work into my DSE using the foglight wiring. Worked a treat.
