waveydavey said:
SpiggyTopes said:
BTW, staying in Constantia in Jan with the family, if you are around I would welcome some relief!
I have to be home in Jan; my wife is having our 3rd baby about then so I will need relief more than you!
If you don't mind can you bring the spare bits then and hopefully I can follow your lead.
I won't be driving down, but I think I can bring the aluminium. If not, I got it from the Building warehouse.
You have the tools? Drill, hacksaw etc?
Shopping list:
All fixings 6mm - just get lots of each in packets so you can return what you don't use
*6mm threaded rod, 1m long (cut it into 4 equal lengths)
*6mm acorn nuts, stainless
*6mm nyloc nuts
*6mm plain nuts
*6mm spring washers
*6mm couplers
*Plenty of large rubber or nylon washers
*large 6mm galv washers
*plenty of cable ties - 300mm minimum (to tie back the surrounding pipes)
*locktite
That's just for the compressor mounting, I guess you have the pneumatic fittings?
