1 - 17 of 17 Posts
2013 RRS HSE
Finally got around to replacing the headliner material in the P38
Figured I would share a few pics before I start my next project, valley gasket.
More than happy to answer any questions, provide other pics, etc. just let me know!
[attachment=3:4ohiksnd]headliner1.jpg[/attachment:4ohiksnd]
[attachment=2:4ohiksnd]headliner2.jpg[/attachment:4ohiksnd]
[attachment=1:4ohiksnd]headliner3.jpg[/attachment:4ohiksnd]
[attachment=0:4ohiksnd]headliner4.jpg[/attachment:4ohiksnd]
yeah that piping looks good.
Is there an OEM part for the sunroof part of the headliner and the also the lining trim that goes around the main part of the headliner around the sunroof hole - I have been told there is not but I replaced my headliner a while ago and these two outstanding pieces now look all the more tatty.
Andy
2013 RRS HSE
Discussion Starter · #6 ·
Thanks for the compliments everyone. I did turn out well, I do have to admit it was not my first time doing a headliner, I used to work in a Perfomance/Aftermarket/Car Stereo shop and spent much time covering interior parts, sub boxes, pillars, and headlines.
Andy, I actually was going to replace the material on the moonroof shade but the original material looks OK still and matches the new headliner well. If you do try and replace it you would need to drop the moonoof assembly to pull it out, really not that difficult to do. Then you need headliner material with the thinnest foam backing you can find. I used 1/4" foam backed headliner material for the part I just did, I think it would work OK on the moonroof panel but seems thicker than the current material. I actually bought enough to do the panel so I may try and do it in the near future.
The surrounding trim piece actually holds up the headliner around the opening for the moonroof, again, mine seems to be in good enough condition that it matches the new material so I did not worry about replacing it. I would think that if it can no longer be sourced from Land Rover you may be able to find the equivalent at a automotive trim shop.
Thanks ESP - I'll have a hunt around the trimmers shops - if anyone knows a good one here in Melboure can they let me know please. I've used a couple on other things but none of them blew my dress up.
Looking at your photos it looks as if the pillar trims are different to mine - I'm guessing that you might have stripped all the fuzzy stuff off with spirit - is that right - I've never seen what they look like with that done - any chance of a close up photo.
Andy
Range Rover MkIII / L322
I have just re-done the headlining and moonroof shade on two Rangies. Getting the shade ( its called the "sun roof - sun shade" in Rave) is simple from the top. The number sequence in Rave is out of sync by one number with the illustration but you can work it out easily. Basically remove the glass and then a few screws from the right hand sunroof rail and push the rail aside. Thats it. The sun shade can now be removed. If any one needs a more detailed explanation I can post it later.
The pic is the sunroof guide rail viewed form the top of the sun roof aperture.
2018 Ranger Rover Sport HSE
Im just did my roof and sunroof
The sun roof is hard to close becuse I used the same materail with foam backing that I used on the roof. I think it will work it's way in after a few uses.
I used the same trim around the sunroof I just matched the materail with the trim and visors.
At the same time I also removed all the fussy stuff off all the pillars.
Good luck
2013 RRS HSE
Discussion Starter · #10 ·
Andy
Andy, I will try and take some pics of the pillars today, I did remove the flocking.
2013 RRS HSE
Discussion Starter · #11 ·
Great to know, since now I feel like I should have done the shade to match the rest 100%
2013 RRS HSE
Discussion Starter · #12 ·
Good luck
How thick was the backing on the material used? That was my one concern with recovering the shade.
I replaced mine last week.
I took the roof board to a motor trimmer and he did the recovering for A$110.
I refitted it. I also replaced the rear drain tubes as one was squashed flat.
Certainly for the trim around the hole. My local LR dealer told me the price yesterday.
BTR2697LUM Finisher, Mist Grey (Gray in US speak :) ), aperture-sunroof
I had the sunshade recovered at the same time as the roof board.
2013 RRS HSE
Discussion Starter · #17 ·
nuyorican420 - That looks amazing!
1 - 17 of 17 Posts
