Hi Everyone
I've noticed that when the FBH has been on by either using the remote keyfob or the self-timer it turns the aircon and recirculation off - but doesn't switch them back on after it's finished.
Is this normal / anyone else noticed this?
I mention it because I always run the aircon ON and the recirculation on Auto (left hand LED on) and it's annoying having to click them on after every use of the FBH.
Hi,
I checked it out on mine, only A/C, and the automatic position turns back on after cutting the FBH.
I'll try to run the recirculation on automatic too and test it again.
I drive it always in fresh air position with both Led's off.
Ronald
Helllo itguy and adera,
Yesterday I cut off the ignition with the recirculation on, left hand LED on, this morning I
started the FBH by means of the remote and after 20 minutes I started the car and
both A/C and recerculation came on! So You are both in double trouble!
Ronald
