1 - 1 of 1 Posts
I had the gearbox repaired after which the above code kept apearing Due to another problem the gear box was replaced, the code still appears internittently, on a tar road I can do 3or 400kms no problem then out of the blue up comes "trans fail safe" code 0740. There is no change in performance or rise in engine revs. The gearbox comunication cables were damaged when the 1st gearbox was replaced (The work was done at our local garage as we are 300kms + from the nearest agents and frankly I don't trust them) I have repaired the cables properly and checked them and the gearbox plug, both are ok. If I travel on a gravel road after 16kms +/- up comes the same fault with the same code, these are being read on a Hawkeye, I have checked the gb oil cooler and the gearbox temperature the gearbox does not oveheat. The gearbox repairs were carried out by probably the best company for this in South Africa. If anybody has any useful sugestions they will be appreciated
1 - 1 of 1 Posts
