Hello, well I failed the smog test. I kinda knew I had a fuel consumption problem but didnt realize how bad. Typical fuel consumption during the test is 1%. I pulled 14%. Ouch! They said there was a leak in the emmisions system somewhere so I'm trying to track it down. I cant find a very good schematic of the sys but upon looking under the hood i did find this.
the white and black tips were unplugged and there was a hose going into the throttle linkage then tee'd off into the dash just above the foot brake that was disconnected and rather deteriorated. What is this, and should both be plugged?
Also,
I removed the A/C unit and there was a hose that looped into the spot that currently has the small piece of tube with the screw in it. Should I continue to keep this plugged or let it breathe free?
More questions to come...!!!!!
Thanks, guys
Also,
Thanks, guys
