Thanks in advance for any and all help in advance. We have in the shop a 1999 4.0S Range Rover. The car has 160,000 miles on it. The customer's complaint is that on start up and backing out of his drive, when brakes are applied, the pedal goes real low. After that the brakes work fine for a while and then goes low on braking again. My thoughts was a master cylinder, but wonder if there may be air in the system causing the problem. There doesn't seem to be a bleed down just holding the brake pedal. Any thoughts?
Hank
Hank
