1 - 11 of 11 Posts
Is there an easy way to get the exhaust pipes from a SC and install them on an HSE? Just curious as I like the look of the pipes coming out the back.
I'm curious if there is any sound difference.
Like a Mercedes differs from an AMG, which uses less baffles.
Carr.
You're pretty familiar with this situation, in fact the HSE would probably achieve a reduction in performance or sound by fitting a RRSC system onto the N/A HSE ?
The design of the RRSC exhaust system was tuned for the Rootes blower on top, which is why it differs from the HSE version - but there's a lot of math involved !
There is nothing stopping you from swapping them over, 'knock yourself out' and go whole hog though be warned of consequences in performance & exhaust flow.
Cheerio,
Vinniman
'88 Highline
Perth, W.A.
Vin, I think they are only talking about fitting the muffler portion of the exhaust on. As the post states it's simply for the tail pipes to stick out. However, a free flowing exhaust typically would not effect the performance. The only time you could possibly loose performance is if you eliminate back pressure. There could be spots on a dyno that you see decreases as well as increases depending on how the flow of the exhaust gasses escape. I highly doubt that by just changing the back section you would loose any performance.
· Premium Member
2019 L405 HSE
CORRECT! I was only planning to change out the muffler itself...they appear to be the exact same size so I don't think it will harm the performance at all and if so, it can't be that noticeable.
Bruin2006 said:
I'm assuming there's no way to install/weld the SC tips onto the HSE exhaust.
You could to be quite honest, where the HSE exits and tucks up under the car the SC exits and bends down and out. it's a simple steel pipe with a stainless steel brushed aluminum looking cover at the end.
Cheers Brew.
I read the title, not the detail and sometimes with my previous aftermarket exhaust work on the Dyno we achieved a reduction in performance on a Honda V-tec !
My mate just fitted mid-pipes to his Nissan Skyline R35 GTR to replace the originals, made more drowning noises with no improvement so went back to the OEM's.
I remember removing a front pod on a Barina back to an original airbox & interior noise was deafening, since back pressures were affected by the barrel muffler ?
Cheerio,
Vinniman
'88 Highline
Perth, W.A.
· Premium Member
2019 L405 HSE
I checked with the local dealer and the parts guy told me that they don't sell just the tips alone...you would have to buy the whole muffler. So for now, I had a local muffler shop weld some stainless tips onto mine that look pretty close to the supercharged ones.
Thanks Duke.
Reminds me of the Overfinch FFRR tested by the "Topgear" TV show from old blighty earlier this decade ? Boy - 'Jezza' absolutely pushed that mansion on wheels !
The Overfinch model appeared to have replaced a rear muffler with twin oval outlets to take into account the additional thrust from the autobahn storming 5.0ltr.
Cheerio,
Vinniman
'88 Highline
Perth, W.A.
http://www.youtube.com/watch?v=CFB-yfMb6ZA
1 - 11 of 11 Posts
