1 - 17 of 17 Posts
hi all
Im loving my v8 but would like to have a bit more sound do you think I could remove large silencer
in middle of RR and replace it with a length of pipe to get some more sound
has any one done this
andy
RIP Our Friend
That has been done by several members. Removing the rear resonator is also an option depending on how much added tone you are looking for.
Mine has no cats - well, except when Suzie the workshop cat (Felis Silvestrus Diagnosticus) takes up residence - and it sounds more-or-less indistinguishable from an unedited one. I suspect the middle pipe surgery will give you a nice woofy boom from the V8, and leaving the middle box but removing the back boxes will give a farty rasp.
Are you running LPG or petrol? I saw RPi had some stainless non-cat front ends for sale, but they said the were for LPG. I didn't think you could run a P38 petrol V8 without cats and still pass the emissions part of the MOT.
In the UK a P38 on LPG should pass the emissions without cats and the tester should carry out the test with the vehicle running on whatever fuel it was presented with, not switch back and forth. However, you'll note that the exhausts mentioned have small "non-restrictive silencers" where the cats would be so that they look like they are fitted and pass the required "cats present" visual test.
Of course it's on LPG ;-) In this case, the previous Finger-Tight Malcolm has cut the sides out of the cats, removed the insides, and (badly) welded them back up.
You're lucky. The Hong Kong Government won't allow private cars to convert to LPG because they heavily subsidise it to encourage commercial vehicles to convert and help reduce our huge pollution problem. Until very recently, it was impossible to purchase a private car running on diesel because that was subsidised too.
Banned
That should become worldwide, the ban that is, not the subsidy. There was a news story in the UK recently that said that the Government were considering increasing the road tax on diesels and charging more for them to enter cities as it has finally been realised that, despite the efforts of manufacturers to cut the emissions, they still pollute far more than petrol cars.
Banned
http://www.telegraph.co.uk/motoring...racks-down-on-Britain-over-air-pollution.html
http://www.express.co.uk/news/uk/49...-road-tax-charges-hit-diesel-drivers-EU-rules
http://www.theguardian.com/world/2014/jul/29/diesel-drivers-may-face-higher-costs-pollution-battle
http://news.sky.com/story/1309480/dirty-diesel-drivers-face-new-tax-in-cities
and plenty of others all saying the same thing. As a motorcyclist as well as a Range Rover driver, I can tell you there is nothing worse than being stuck in traffic behind a diesel car with the stink from the exhaust drifting up inside your crash helmet.
Discussion Starter · #15 ·
hi mate not to sure where to go now definatly want to open her up but now wondering if changing rear boxes would be
better than center box ?
Banned
As you are running on LPG you can bash the guts out of the cats so it looks like they are still there but don't have anything inside them. That will give it a bit more of a grumble. The centre box is easy to take out. One end is just a straight pipe but the other end has a slight S bend in it. You can cut the silencer out and weld a straight length of pipe in it's place. If it's too noisy it isn't too expensive to replace it with a new one, around £50 if you shop around. If you've got the twin tailpipes though, they are expensive to replace if you don't like.
1 - 17 of 17 Posts
