1 - 10 of 10 Posts
On a 1996 p38 4.0, both my temperature and fuel gauges are acting erratically, the first shows car overheating ( even the red light comes on for few seconds) as I have just started driving in a blizzard.
The fuel gauge shows 1/4 of a tank when I just filled gas, but it corrects itself later as I am driving ( luckily not the other way around and risking running out of gas).
Is this a sensor issue? Or instrument panel one?
On a 96, you have loose connection issues most likely......
1- Check fusebox CAREFULLY for burn't connections, loose plugs on the underside, Burn't pins on underside coloured plugs. If it is the factory fusebox, it may be time for a new one
2- Bad earth connection. (Most likely) Get RAVE, find locations for earth points and remove, clean, and tighten ALL of them. The AC issue is a bit of a pointer for that one,
Beyond that, there are any number of plugs that could be causing issues, but start with the 2 above.
Do as Bolt says... if that doesn't help check this
another favourite is the plug under the expansion tank, various lines for the sensors are in there.
your tank could be simply a loose connector on top of the tank
Discussion Starter · #6 ·
I have done that already.
Discussion Starter · #7 ·
Did that too, no luck.
Discussion Starter · #8 ·
Choice 2 did the trick after a thorough inspection, the only earth photographed on RAVE that I couldn’t find, was the one on the LH of the engine ( the photo looked alien in direct comparison to my engine 96 SE 4.0), but I am glad it was not the source.
Glad that is sorted!
Which of the many earth points do you believe was the culprit?
Discussion Starter · #10 ·
Thank you Bolt for the follow up.
I am suspecting the thick metal wire between the engine block and the chassis with an earth point on either end ( black one in photo) tons of road grime and dirt baked on, due to mixing with engine oil ( I have a slow oil leak).
The fuel gauge is still acting up though, so I am suspecting a sensor issue, thoughts?
1 - 10 of 10 Posts
