Hello all,
I sometimes get this ENGINE/TRANSMISSION warning light when backing my boat back into my garage. Just curious to see if someone else have this problem.
Truck info:
2007 Range Rover Sport Supercharged
Boat is a 2008 Reinell 207LS 3400lb dry weight
thanks,
PVang
Is it a transmission message, or the amber check engine light?
If you are absolute about the correlation on backing the boat, my guess would be something is wrong with the reverse lights on the trailer, if they are backfeeding voltage into the brake light signal, it can cause transmission, and other various faults.
If this is every time you do this, try backing it in with the trailer harness disconnected, and see if that resolves it.
No this is not a transmission message, just the amber check engine light. That's a good point, I'll try to unhook it next time. This happens only once in a while when backing the boat into the garage.
