1 - 20 of 21 Posts
Hello All,
My 2016 Range Rover L405 sounds like a diesel and has a ticking that is driving me crazy. I have attached a video to see if any RR experts here can figure out what it is! Still under warranty but my local dealerships suck. Would like to have an idea before I walk in there! Please help me it is killing me from the inside.
Thanks!
Sal
Video: [video] https://youtu.be/8mjErhXc_CU[/video]
Discussion Starter · #6 ·
I just went to the car and started reving, the ticking speeds up, and there was a strange grinding noise coming from under the vehicle (Drivers side)
Salman, get rid of those ugly black side vents! Just kidding. Peter Benevidias of Land Rover Pasadena can help you. Just call him ahead of time to schedule an appt. they have free loaner ****ty evoquesbut still convenient. It honestly sounds like a bad rocker arm or lifter. You need to get it fixed ASAP! Keep us posted. Some real housewife didn’t change her oil...
Discussion Starter · #8 ·
Thanks Mark, ill reach out to Peter. This is the first pre-owned vehicle I have ever purchased, and it was a CPO. Probably the last time. Its better to have it in one set of hands like my other cars.
Ill keep the forum posted on the result.
One more thing. When you call him leave a message. He will call you back from a blocked number. He's so busy he doesn't answer his phone ever. But always calls back the same day.
2019-2021 Range Rover Sport
I would do a visual inspection of the exhaust manifold on that side sometimes it could be a leaky exhaust... since you said it was only on the drivers side that is where the high pressure fuel pumps are located, they are known for becoming noisy. check the lower portion of the engine to see if it is coming from there. If it were a rocker arm the noise would be coming from on top.
just google Noisy high pressure fuel pump and you will see many videos of cars with noise just like yours from a bad fuel pump. as I said before the location of your complaint gives it away.
It sounds like a stuck lifter for the high pressure fuel pump cam..
They all sound like that..yours is just...loud
metallic sounding
not normal
take it in immediately
2012 Range Rover MkIII / L322
Sal,
Does your car have any other symptoms? Mine is making a similar noise that also speeds up with the revs, but not quite as loud. The people at the dealer refuse to acknowledge that the noise is unusual, which I know for a fact that it is because it is a new occurrence. My car is also down on power when attempting hard acceleration.
Discussion Starter · #14 ·
Mine doesn't seem to have any performance issues, when i pull into my parking garage at work, the valets know i'm pulling in because of the ticking. Power feels fine, and fuel economy is doing pretty well. I haven't taken it in yet, I am on vacation on the eastern seaboard, but the moment I get back, it will go to the dealer. Once complete i will post what the dealer acknowledged, and the paperwork for other members of this forum to get some insight.
Discussion Starter · #15 ·
just dropped it off to the dealer. Will update everyone once I get it back. They gave me a Velar R Dynamic and I find it claustrophobic with surprisingly cheap materials.
Discussion Starter · #17 ·
What was the ultimate outcome, issue and resolution with your RR and the noise?
I took it in to the dealership and after working on it, they said the best they can do is add new insulation. However I think its either a lifter issue, or I am going to change my oil to Liqui Moly LR Tech as I hear that really works well with this engine according to some master techs at LR Santa Monica. The ticking is annoying and I've started driving my BMW M760i more. Sorry I didnt update!!
Also once I change to Liqui Moly I will post dB's and vibration information before and after.
Salmon, call Freddie.310-912-4591 he’s in Inglewood. He will tell you the truth. He’s an independent mechanic.
Discussion Starter · #19 ·
Thanks Mark. will do. really appreciate the extra assistance with this!
  • Like
Reactions: mark1107
1 - 20 of 21 Posts
