Right temp sender reading -40 on live data, changed sensor 3 times now and dicided it must be somthing else so have cheacked the wiring, voltages etc etc and yes well...
from one side of the plug i get a voltage reading of about 4.75 volts (this is a cheap well battered multi meter so will not be exact) and the other side i get a voltage reading of 9.28.
so look up manual and take reading from ECU pin (input) with it disconected from the sensor i get a 4.75 volt reading with it conected 9.2 volts. now according to the manual voltage should drop as engine warms up bur engine warm and i get this.
I am missing somthing or wiring/ECU fault?
pre 99 gems 4.0
pre 99 gems 4.0
