Hi, would anyone happen to know what's the story with these pistons? Block, crank, rods are stock 4.6, just the pistons look different than standard.
Pistons ?
Block #60D
Standard piston
Super Moderator
They are 'pocketted' pistons with cut outs to allow for a high lift cam to be fitted. Does the engine have a standard or sports camshaft?
Cam is still in the block. Any way I can tell without taking it out (any stamped numbers to look for etc)?
The pistons in the engine are for 3 or 4 valve heads, the piston on the bottom is a stock one.
May be high comp pistons?
See if the dish on the pistons in your block are smaller as on the stock one.
Super Moderator
As far as I know, nobody has ever made 3 or 4 valve heads for the Land Rover V8. As said, they are pocketted pistons to allow bigger valve and/or a high lift camshaft to be fitted. See the spec on this engine http://www.v8developments.co.uk/pro...ines/4.6_performance_short_engine/index.shtml
Then the piston would have a pocket in the center.
These pistons could come from a completely different engine.
I've got 4 liter HC pistons in my 4.6, should have a CR from about 10.9 : 1, and there is plenty of room for the valves, no need for pockets in those pistons
