Hi
I have a 4.6 with an annoying oil leak (no surprise there)
I wiped the sprayed oil off of everything i could reach the other afternoon and started it up. There was a steady trickle coming down the filter (which is tight) but I couldnt tell whether it was coming from the filter or above and running down.
Its going to the garage tomorrow but has anyone had similar ?
Steve
As Jos says,l it could be the oil pressure switch. There was a TSB on this.
I had it occur on mine, too.
javars said:
Hi
Steve
Its started already then Steve? :lol:
BTW, you better show off the new (not a spot of rust) Range Rover with a photo!
Rich998a said:
javars said:
Hi
Steve
Its funny after I posted the problem, I thought about the switch but had no idea it was there !.
Picked one up today, hopefully sorted tomorrow.
And yes Rich, will post pics when new wheels fitted and body polished ! Wouldnt want to let the side down.
Steve
Yep was the switch. Thanks for info
