Well, I'm wrapping up a fairly major service for my '04 L322 including changing the upper timing cover gaskets and the valley pan gasket and a million other things, but when reassembling, I seem to be having trouble getting the darn engine oil dipstick tube back into place. I can get it in the hole, but no matter how I twist or turn it, it seems like the bracket holes don't want to come anywhere close to lining up with those bottom two studs on the passenger side valve cover where they're supposed to go.
I know it's a long shot, but does anybody happen to have any advice or tips/tricks to get that engine oil dipstick lined up correctly? Maybe even some photos of what their tube looks like as it snakes down the engine bay? That would be extremely helpful... It seems like it was really difficult to get out, but went back in pretty easily. Not sure if this because I'm not threading it through the engine bay correctly or if it's just because the washer and o-ring were holding it down when I was trying to remove it.
