put the EKA code in,the doors all unlocked then when i put the key in and tried to start the engine the disabled message cameon as well as window set message.wen i pressed the unlock button on the remote nothing happened!!help
Have you a handbook for your vehicle, details are worth reading in detail.
Also no EKA code can be done with ANY doors open.....inc bonnet.
You have 3 allowable attempts after which it goes into lock down for 1 hour.
Make sure you arnt trying the radio code.....like I once did :doh:
thanks for the reply,the first time i tried the eka code the alarm started,then tried again with minor success-no alarm but engine dsabled .usually when this message appears i can press the remote and hey presto!I have scoured the common problems pages for a section I found the other day about syncing the handset by putting it in the lock whilst keeping the button pressed-can't remember the sequence though!! :( :(
