Engine Code Question - slip in the 4th gear of the transmission
Looking at picking up another P38 and came across a sweet 1999 at a good price. Issue being check engine light on, code showing "Slip in 4th gear". Confusing to me as I've never seen that issue and there appears to be no noticeable issue with trans. Can't seem to find much after sifting thru posts to determine is this is ECU, solenoid, or something else.
Anyone experience this code before?
RIP Our Friend
Re: Engine Code Question - slip in the 4th gear of the transmission
What is the actual code?
RIP Our Friend
P1775 in Range Rover world usually just means gearbox fault. This just means the tranny ECU has logged some fault of some kind. Without an additional code it usually means the first signs of weak voltage.
