AB sells a genuine LR block heater that lists for around $150. I've just installed a Phillips from O'Reilly (part no. 3100039) that was $22 and is built a little better. For those of you reading this and living in hospitable climes despite the subject line: It's a small electric heater which fits inside the block through a freeze plug opening. You pry out the freeze plug, insert the block heater which has a 110V power cord, and after refilling you can plug it into a wall outlet to keep the engine warm when it's waaaaay too cold out.
Like an electric blanket for your car, dont think I need one in Cape Town but the thought of my car being pampered all night long during a cold winter appeals to me
I remember my dad had block heaters on his vehicles when I was growing up in South Dakota. They seem to have disappeared over the years with fuel injection. Do you still need them up north?
No vehicle needs them, but imagine getting into a car that has a warm block
ready to start. It also saves quite a bit of fuel. I use mine 100% of the time where
I have access to 220V socket.
I would prefer a Webasto or Eberspacher.
I've used them for years. Typical winter here is probably like the land of the Midnight Sun - a few months of -30F at night but warms up to -10 during the day. Electricity is relatively cheap here, so the cost is probably less than $5 US per month to keep it plugged in, and I know I save more than that in gasoline. It sits outside all day at work, but starts just fine without being plugged in. I've had a lot of vehicles over the years, and nothing, absolutely nothing, starts and runs as well as the RR when it's well below zero.
I have fitted a Webasto heater to my p38 DSE. Works on 240v mains. Has a pump on it and is plumbed into the heater circuit.
I originally had it fitted to a classic which had a 4L Perkins diesel engine and was a pig to start.
My DSE doesn't have a starting problem but in the winter it is nice to flick a switch, go and have breakfast, and then get into a car that is like toast.
Most wear and tear occurs when the engine is cold.
Dave
