1 - 20 of 51 Posts
I've had my 2010 Range Rover Supercharged for about two and a half years (bought from Jaguar Land Rover dealership) and have experienced battery/electrical issues ever since (battery is too low to start car). Initially it would happen every 8 to 12 months, but now it happens every couple of days. It's been taken into the dealership's service center each time and so far with their troubleshooting they've replaced the fuse box under hood (because 10 circuits were drawing power when the car was off/shutdown), replaced the alternator, replaced the heater/blower (it was drawing power when the car was off/shutdown) and between all the visits they've had to replaced the battery 3 to 5 times. Lately after each fix/visit the car would start reliably for anywhere between 3 days to 2 weeks, but fail to start again. I was really hoping the last fix (heater/blower replacement) was the final/true fix to end all this but unfortunately its not. The car sat for 5 days and I went to start it - there weren't any cabin lights and the engine didn't bother trying to turn. Multi-meter says the battery is at 7.89 V. At this point I don't know if there's something else still powering on and drawing power when the car is shutdown or the dealership keeps installing failed batteries. Regardless, I'm at my wits end and just about to lose it.
Has anyone experienced similar issues and know of a fix? Or anyone have any ideas whatsoever as to how to find the true culprit of this problem?
Common issue among every car maker out there. Something fails and you have a battery drain. You need to take the time to find the circuit or circuits that are draining, find the issue and repair it. You can trip your door latch to make the systems think the door is closed and the BCM goes to sleep. Then you can take a multimeter to your glove box fuse box and test each fuse to find the draw or draws. make notes. Open the hood, disconnect the hood open switch and when the BCM goes to sleep, test every fuse in the underhood fuse box. Most circuits will read zero or very small pull. Those circuits will be for radio memory etc. Any fuse that shows a larger draw is suspect.
Your other option is find an indie in whatever part of Seattle you are in and log a huge labour bill for circuit testing.
Listen to what RRToadHall stated. He is 100% spot on regarding how you need to trouble shoot your problem.
If you do not do the work yourself insist that the dealership does it and talk to the actual mechanic that is going to or did it (assuming it is under warranty). (Regarding warranty - if it ever had it or you paid for anything regarding this issue I would say the dealership should see it to the conclusion at no expense to you.)
For a story - my neighbor has a 2001 Jag XJ8 - he has the same issues you have. He has brought it in countless times to an independent shop for extended warranty work and they have done the same thing you describe. For the last two years I have been telling him he has to do exactly what RRToadHall suggests. He doesn't listen. Car keeps dying on him. At one point he jumped it and blew the engine computer - trip to the dealership and they put in a new one under his extended warranty as it was a dealer item only. Same problem. He was told he has to drive the car at least every three days a good distance. No one has bothered to do a real drain trouble shooting. Now when he complains I just laugh at him. I will no longer let him borrow my charger. I am sure the shop laughs at him as they keep getting to bill the extended warranty company for a tow, battery charge and/or swap.
Some circuit in the system on your Rover is not shutting down correctly due to a fault, something is improperly grounding out or similar - the only way to find this is to measure voltage and current of every system until the fault is found. At this point I would not rely on the factory computer the dealership is using - it has failed you how many times? Make them pull out a VOM and do it old school - the fault is there waiting to be found.
Your problem is not common or you would find a solution searching the internet as others would have the same issue or Range Rover would have been able to fix it because the lot would be full of RR just like yours awaiting repairs. They would assign a team of engineers to figure out the problem, find the solution and issue a TSB. As it is not common - something specific is wrong - they just need to find it. They have taken your money - make them earn it.
Report back so I can tell my neighbor.
They've already done old school circuit testing (i.e., shutdown, wait and measure) 2 to 3 times already, each time taking 4 to 6 weeks (and a full shutdown - the one that occurs hours later after the engine is fully off, not the soft 2 minute shutdown). The culprit the first time was the hood fuse box (drawing power on 10 different circuits), a door module the second time and the heater/blower the third time. The last time took 6 weeks because that circuit was one of the last on the list. I can't stand the thought of driving those crappy Discovery Sport loaners for another 6 weeks LOL!
I'm starting to think it's NOT one particular circuit behind these drains anymore because there's a different culprit each time - unless there's a particular circuit or component that falsely tells OR corrupts other circuits forcing them to power on?? Feels like when I take it in again a different circuit/module will be the culprit this time, thus possibly giving us a false positive.
P.S. - Extended warranty is expiring in a couple of months, so I'm hoping this gets figured out soon.
If it is under warranty let the dealer handle it.
I feel your pain. I will tell you a story to help flush out the difficulty in trouble shooting and why sometimes it doesn't work just swapping parts.
Recently I had to trouble shoot an "anti-skid" warning on my Volvo. As the Volvo was out of state, it was brought to an area dealer. They plugged it into their computer and said it was one of two modules - they could not tell which one because the way the circuit was wired either would throw the code. It was either the clock spring or DEM. So it was hit or miss. Based on their experience they stated most of the time, based on my vehicle and mileage it was a failing clock spring. They were honest and upfront. Unwilling to spend the $600 or so with an out of state dealer I could never work with again I didn't have the repairs done. When it got home and back under my control I did my own testing and thinking. I figured the best approach is to try the clock spring replacement. I bought a used one for $50 from a local wrecker and replaced it. During the process I found out the cause of the failure - someone spilled a Smoothie and it dripped all over and down the back of the steering wheel. The clock spring was caked with gunk and it appeared that indeed it was compromised. I cleaned everything up and noticed some corrosion on a connector on the male side of the clock spring and on the female side of the steering wheel module, one not mentioned by the dealer as a possible cause of the Volvo's issues. The clock spring plugs into the steering wheel module, from there signals go various places and ultimately to the DEM. I put everything back together and had no issues for 6 months. "Anti-skid" warning came back and another shop I use reported back with the same diagnosis as the original dealer.
Unwilling to accept the diagnosis as I understood how everything works and knew my clock-spring was fine and I did not think it was the DEM because the code was intermittent I pondered the issue for a month. After looking at the photos of the various modules I took while doing the repair, it dawned on me that when I did the original work the steering wheel module female side had corrosion which I cleaned as best I could. If that connection was still dirty it could cause an intermittent fault code. The module itself was working fine and would report back as working, but the connection was not. Even though the steering module would not throw a fault code as it was working fine, it would not accept the inputs of the clock-spring - and the computer would say the clock-spring or DEM was bad. What was bad was the female connector on the steering wheel module (something that would not throw a code) - I reasoned this bad connection would stop the flow of information upstream. So I ordered a used steering module off Ebay for $22 delivered and had it installed. For $22 and an hour of easy work it was worth testing my theory. Problem solved.
The point of my story is maybe you have a bad connection somewhere and this connection is the cause of your issues. In your case as they replaced the under the hood fuse box - I would look at the wiring harness. It will not throw a code or appear to drain power on any test and upon visible inspection look just fine - but it is the path all signals flow through. Right now they are just throwing parts at the car, without looking at the harness connections. The Dealer has to step back, look at the wiring diagram and figure out which part of the wiring harness - specifically which harness junction - could be at issue.
When they changed the hood fuse box - what did they see? Was there liquid intrusion? Did they only change one side of a two sided problem?
Just something to think about. Keep pushing your warranty claims and take a long road trip on their loaner Discovery.
Okay, before I have it towed to the dealership again, what can I look for or tinker with to quickly test the grounding or bad wiring theory? The battery voltage is now down to 2.66 (was 7.89 yesterday), by the way.
To drain the battery that fast - there has to be a pretty serious leak to ground somewhere. I had a similar issue a while ago on a different car - I did the fuse test on each circuit and couldn’t find anything.
Is the alternator warm to the touch ? My issue was bad alternator diodes causing the battery to drain to ground when the power was off. After leaving car overnight - alternator was warm to touch. You said alternator was replaced . Why ? Was it not putting out sufficient voltage at idle ? My reman denso alternator also had bad diodes after less than a year. Worth checking ...
Faulty ignition switch could also be another cause that keeps power alive or shorting to ground - when off. But this could be anywhere in the wiring loom - you probably need an old school auto electric guy to trouble shoot it - not one of the younger dealer tech guys ....
First thing to do is disconnect your battery, negative first, and charge the battery until it is full.
What do you have in the form of tools? Do you have any kind of electrical tester or VOM?
Discussion Starter #12
The alternator was replaced because I kept getting the Charging System Fault error. This error occurred popped up after the hood fuse box replacement and of course I got a dead battery again. They were actually stumped on why the error was coming up and they brought in a tech from another dealership and he recommended the alternator be replaced.
...you probably need an old school auto electric guy to trouble shoot it - not one of the younger dealer tech guys ....
Exactly what I was thinking, not sure if they'll honor that request though
Well I have some equipment for when I get back into tinkering with solar and 18650 li-on batteries stuff; I have a 150W 12A DC multi-charger which can charge and discharge a sealed lead acid battery, a AC to DC 12V 33A power supply (can adjust output from 10.4 to 15.2 volts), DC 6.5-100V 0-100A LCD display digital current voltage power energy meter (multimeter/ammeter/voltmeter) with 100A current shunt (can't remember why I got this, LOL), a plain ol' Radio Shack AC & DC current multimeter and a cheapo Amazon clamp style AC & DC current multimeter. Any of these helpful?
Discussion Starter #13
oh, and a 12/24V 20A solar charger controller
You have the diagnosis tools required and sound like you have the skill set and knowledge to use them.
Watch the YouTube video I linked above and it explains the tools, process and procedure better than writing would (at least my writing).
It appears no one has looked at the harness/wiring (in between) so far and has just been swapping out parts (the ends).
Heh, I actually don't have the skill set, but I am picking up a ton of info so far. The battery is likely dead dead now so I don't think the parasitic draw test would yield anything (there's probably no current). I'll try charging it with the hobby charger and then doing the parasitic draw test. If unsuccessful I have no choice but have it towed to the dealership again and burn through the rest of the warranty hoping they find a true fix. If the warranty runs out without a true fix I'll just do what other RR owners have done; install an AGM battery and then a secondary battery in the boot/trunk/cargo area to help lessen the chances of the car not starting.
Thanks everyone for your help. Much appreciated!
what size battery changer are you using? I suggest to use a 6 amp charger and charge the battery for 5 hours.
disconnect it from the charging system first.
Usually an alternator can be damaged by using a jump starting charge box,
this will spike the diodes ,
and then the alternator can kill the battery either from an internal short or under charging the battery.
at 1500 RPM after 2 mins you should see a charge of 14.4 .
If its charging under 13.5 then the battery will die.
If your doing anything in the truck like listening to the stereo or in any other way running any of the electronics in the truck,
the engine must also be running or you will kill the battery in 20 mins or less.
NOTE on these trucks their are numerous computer systems that turn on when the ignition key is powered, not just a radio for example
Our cooling fan for the E box seems to run a long time and once after opening the car door after a couple of hours the E fan was running. Not sure if it came on due to opening car or it never shut off. It has a heat sensor that activates it at around 95F. A temp in several parts of the world that is not hard to reach even with the engine off. Having said that we have not had a no start from a dead battery until the canadian tire battery I got when we bought the car died 3 months before the 3 year warranty was up. I load tested the battery to find the failure. If your battery has dropped that much i hope it will recover from that deep discharge. Let us know what the voltage is at the battery as mentioned above and good luck and some lateral thinking.
Discussion Starter #18
It's a brand new OEM battery (Interstate Batteries, Mega-Tron Plus 49/H8, 100 Ah, 910 cranking amps, 730 cold cranking amps, 175 minutes reserve capacity @ 25A). I contacted the dealership and they've just about had it with this car - they'll look at it to see if the problem lies with the work they did (the blower, hood fuse box or door module) as to honor their shop's 12k miles/12 months warranty. No troubleshooting/diagnosing the dead battery issue anymore, no extensive labor hours, no loaners, no more courtesies. I still plan on taking it in next week, but with that grim news I figured in the mean time I should still try to see what I can find out myself (and start shopping for a bicycle LOL). I started the process of charging the battery with the hobby/multi-charger (see notes below). Based on the readings below is it safe to say the battery is good (discharges at a normal rate while disconnected) and there's definitely a parasitic draw? Does it tell anything else?
2.35V, 0.033A - battery still connected to car, current tested also
4.26V - battery disconnected from car, voltage is from battery by itself. Started charging with hobby/multi-charger (initially got "low voltage" error when set charge to 6A at 12V, so changed it to 2A at 6V and that started successfully)
11.41V - after 2 hours on the charger (2A at 6V). Disconnected charger because I had to run to a client and didn't feel safe leaving the charging unattended.
10.82V - after 5 hours of being off the charger (0.59 drop in voltage from last reading)
10.75V - after 20 hours of being off the charger (0.07 drop in voltage from last reading, 0.66 overall)
10.47V - after 27 hours of being off the charger (0.28 drop in voltage from last reading, 0.94 overall). Charger reconnected and set to charge 6A at 12V (no error this time)
11.48V - after 2 hours on the charger (6A at 12V). Got "over capacity cutoff" error and charging stopped, probably because that's a builtin safety setting in the charger and I didn't change it's default (likely 2500 mA/2.5A). Disconnected charger again for safely (until I have a block of hours to try again).
11.41V - after 4 hours of being off the charger from the last partial charge (0.07 drop in voltage)
Bruzer,have you ever connected an amp meter in series at the negative terminal of the battery and waited an hour or so to let the system go to sleep and observed the actual amperage draw? The amount of draw may help determine what system or systems are remaining powered up. Just a thought. Normal should be less than a 100 ma.
Bruzer - You really should watch the video I linked earlier. It is extremely easy to follow and tells you exactly what to do. Your earlier response reflects you have the proper meter.
Once you watch the video you will say "Dude - I can do this".
1 - 20 of 51 Posts
