I plan to remove this solenoid, next time I'm in there. Call it "preventative maintenance", or my private "Tea Party Moment". (I've removed a lot of such silliness, by and by.)classicjack said:Remove wood grain shifter cover by prying. remove e clip, remove nut, remove shifter handle, remove selector off shaft, pry inset panel from consol ( plastic piece with iluminated P R N D 3 2 1 ) , there is a pin activated by a solenoid which can be pryed out so shifter can be moved .
Actually I think it is a "Civil War" moment as it was something specified by your fellow countrymen and not a nuisance anywhere else.nails said:I plan to remove this solenoid, next time I'm in there. Call it "preventative maintenance", or my private "Tea Party Moment". (I've removed a lot of such silliness, by and by.)classicjack said:Remove wood grain shifter cover by prying. remove e clip, remove nut, remove shifter handle, remove selector off shaft, pry inset panel from consol ( plastic piece with iluminated P R N D 3 2 1 ) , there is a pin activated by a solenoid which can be pryed out so shifter can be moved .
