Does anyone know 1) where the wiring from the rear left interior light is routed 2) same for the rear passenger side door speaker wiring and 3) where the factory towing electrics wiring went?
My light doesn’t work even if I swap the two over, the unit doesn’t work nor does the wire going to it, the speakers in the rear passenger side door don’t work at all and neither does the sub, also on the towing electrics, mine were kinda damaged when I got the car and wiring potentially a bit exposed at the end so I was wondering if that could’ve buggered my left hand side although the wiring harness connects on the right near the lights (since removed)
I don’t know what to do about it all!
TIA
Edit: Whilst on the topic of electrical gremlins, my driver side tweeter makes a lot of noise nowadays, but usually only when the radio is Off. It crackles at random intervals and also makes strange high pitched noises, any idea what that's likely to be? Quite annoying tbf
1995-2002 Range Rover Classic
b pillar left side under carpet there is a connector just behind the rear of the front seat.
