At first when this happened I assumed that it was either the battery or the alternator or both. Typical symptoms, error messages followed by low battery, car dies. When it happened last weekend I managed to get home, ordered a new alternator and battery.
They were installed last night, and after checking over wiring etc, I went out for a test drive.
I was optimistic as I got further and further from the house, and then ‘BEEP BEEP BEEP’ SRS failure, traction failure, bla, bla, bla, bla.
I managed to get home and rather than jumping to conclusions have had a think.
When the car dies, it doesn’t do it in a gradual manner as you would expect with a dying battery. It happens very suddenly and the engine cuts out, leaving you with no power steering, brakes etc, not good. If I then wait a few minutes I can start the car again and
then, obviously take the quickest route home. It dies several more times before I reach the safety of the carport.
Now I’m thinking that this may be heat related, there is a component that warms up but once it reaches a certain ‘operating’ temperature it fails.
I had a look at the wiring whilst the alternator and battery were out, but couldn’t spot anything obvious. The fusebox (top) seemed ok, and there was no burning smell or signs of hotspots, once I got back.
Does anybody know of anything obvious I could check when I get home tonight?
At least I have a new battery and alternator. :lol: :x
