Hi to you all.
Love my 2011 L322 Range Rover Supercharged , but the other day i was driving home and it died on me.
It comes up with lots of : lost communication faults but still has power to open the doors and radio for example. However it will not start the engine . Can anybody please help me. Regards Jake.
Start from the beginning and have the battery load tested.
L322's are especially reliant on a perfect battery.
Rob
Rob
Hello Rob.
Thanks for your help , i will try that first but it is only a two week old battery. If that is not it what else would you suggest please.
If the battery was just replaced, double check the tightness of the battery terminals. A loose terminal may give you the same fault.
You’ll need a 13 MM wrench for the +ve and a 10mm wrench for the -ve.
Rob
Rob
Hey Rob.
Thanks again for your help , that will be the next thing i check.
Wish me luck.
Regards Jason
Jake
If the battery is only 2 weeks old and the terminals are tight etc then the next port of call will be to check the output from the alternator. Either charge the battery or use jump leads to start the car and put a voltmeter across the battery terminals. You should see a reading of around 14.5v. Anything much less than that and your alternator is goosed.
Good luck
Cheers, Mark
