97 RR p38 4.0SE.
Head gaskets replaced. Post engine work electrical problem as follows.
As soon as the battery (which had been dead for a while) was replaced all dash lights come on with no LED or instrument feed. This is without the key in the ignition.
All grounds, yes all of them, have been cleaned.
Mechanic insisted a wire must have broke during repair.
A new engine wiring harness was installed with no cure to the problem.
Fuse 1 has power.
When the ground for the instrument cluster is pulled loose the lights go off.
Starts and runs great but no instruments.
Not sure what to look at next.
Fuse 1 has power.
