Old matrix spewed coolant inside so had to replace. Managed to removed dash and replace the matrix. All went back together and no leaks. Only problem is certain electrical equipment is now not working.
Interior lighting
Puddle lights on doors
Bonet (hood) inside light
Power mirrors
heater blower
lighting behind heater control panel
Clock
drivers seat motors
Air con is working by the way
Checked fuses, can't see any connections that have not been put back, obviously there is one common issue to stop these all from working?
Thanks for any help!
Discussion Starter #2
always helps to look twice, found blown fuse, all good except heater bower not working. wiring from blower speed selector getting on the warm side
1995-2002 Range Rover Classic
have you double checked your ground points? the are at least 2 main grounds in the general area of the tunnel which if disturbed could cause issues.
managed to remove both side covers to access the motor, with fan speed switched on motor gets hot but does not turn, can turn by hand so doesn't seem obstructed
