Everything was working fine, then a couple of weeks ago I must have left something on & came out to a flat battery, upon trying to start, she just 'clicked & popped' & & obviously wouldn't start, so out comes the power-pack & instant startup, trouble is, 'AIRBAG FAULT' came up on the dash display, & the 'SRS' was flashing on the dash as well!!
The car runs perfect & I can delete the airbag message by pressing the lower button on the indicator stalk.
My question is this, I feel certain there IS NOT an airbag fault as its too much of a coincidence that it all started when the battery went flat, so, would it clear the fault-code if the battery was disconnected??
I have a Rovacom-lite, Diesel ecu, suspension ecu, body ecu, etc. but of course, NOT the SRS!!
Discussion Starter #2
Sorted, I just KNEW all was good, found an independent LR workshop in Wakefield, reset the fault code for £25.00!! & it hasn't returned. All ok now.
