Have a p38 95dec all working fine except for electric windows, wipers and A/C no fuse problem checked every one of them.. Any clues please
Has it ever worked or have you bought it with these faults? Underbonnet fuseboxes burn out and as there are a number of different ones it's possible that the fusebox is failing or it has already failed and someone has replaced it with the wrong one.
Hi Richard yes bought it with loads of problem but resolved one by one. Need to reset bcem to get it to work for some time but lately this is not working too.
Thanks Richard for the reply in fact bought that RR with loads of problem but resolved it one by one but that fault with the window wipper and a/C been there since I had it but no one was able to clear it. When I reset the bcem it does work once in a while. I even changed the bcem engine unit and it worked fine until the new bcem got hard bricked and won't get out of immobilized state even with key fob so I had to go back to my old bcem to run the car.
RIP Our Friend
Ruben, you can not change BeCMs without have them programmed. First off test your front door latches using the stickie directions above.
