EKA - door switch broken, entering code with wiring - managed it, but unsure how!
I've had to do this a few times and I've been successful, trouble is, I can never remember how... I suspect my door switches are dodgy, I know for certain the door ajar switch is - if the wire for it is connected, the lights etc are constantly turning on and the relays in the doorstations go mad. So that wire is for now not connected to the driver's door latch connector. I can live without the lights coming on etc. When all is well with the car and it hasn't immobilised itself - the key in the door lock does operate the central locking properly both locking and unlocking as you'd expect, and it doesn't unlock itself or lock itself at all at random - that I'm aware of. But when it comes to entering the EKA code, I haven't had a single response from the sidelights indicator. On the other hand, when I take the CDL switch and key switch wires and touch them to ground in various ways, I do.
Its just getting the combination of which wires to touch to ground together that gets me. Add in the additional first 4 turns to 'lock' that my owner's manual states I'm supposed to do (its a 1996 model), and I get even more confused. I'm 99% sure I actually don't have to do this - after managing to lock out yet again and having to wait 30 minutes, I managed to enter the code on the first attempt without the first four locks. The central locking all popped up, and it started. Great. Till next time the battery dies, and I've forgotten again how I managed it. Replacing the door latch would be best - yes, but I can't do that right now.
Thinking about the initial four locks if I do need to do them - should I get the sidelight indicator flash for those? Or does it not flash, but silently becomes ready for the first digit?
I know the 'key switch' microswitch is activated when the key is turned in either direction. The CDL switch then lets things know whether the key was turned to unlock or lock, as this switch is only closed in one of the directions by the lock, turned by either the key or the CDL motor (right?).
From tonight's escapades entering the code, it seems to me that the CDL switch is closed when the latch is unlocked. Is that right? I had the door lock itself unplugged, and the CDL switch wire bridged to ground as if it were closed in the latch. If I remove the bridge to ground, the CDL locks all of the doors (except the drivers obviously, which was unplugged). So whenever the car is unlocked, this switch should be closed it seems.
In theory then, if I don't have to start with the 4 locks, I should bridge the switch wires to ground as below:
Digit 1) - Ground CDL switch, tap key switch * number, unground CDL switch (unlock)
Digit 2) - Key switch * number (lock)
Digit 3) - Ground CDL switch, tap key switch * number, unground CDL switch (unlock)
Digit 4) - Key switch * number (lock)
One last unlock - ground CDL switch, tap key switch
Does that seem right if I'm making any sense? In theory if I do have to start with the first four locks, I just need to ground the key switch wire on its own to ground, but as I say - it seems I don't need to. I'd disconnect the battery again to force me to enter the code and try and clear this up... but I want to drive it tomorrow and its too cold to sit outside playing with it now
