Ok heres a question. If the later injection systems are based on a 7 series BMW would a BMW ecu run a P38 and how would it run?
Well it was a thought, can't you tell I'm bored!!
RIP Our Friend
:think: more importantly, would the ECU and BeCM talk security wise. A good excersise would be to do some sensor cross referencing to see if the sensor values are similar. Very interesting idea though.
What i can work out is all the bosch motronic ecu's are the same, except the configuration is different.
The car based ecu (BMW) doesn't hold any security links that the range rover ecu requires to link to the becm.
I used a bmw ecu on a racer that had the P38 diesel. it was easier to fit that ecu than bypass the security on the P38 EDC ecu.
Hi Rick,
It was just one of those silly things that skips through the mind while sitting in a traffic jam!
This together with a TVR ECU in my classic.
hope your well.
