Hello.
4.6. HSE, 1996. 2x Lambda. GEMS Lucas
The problem looks like this
1. Check works, but does not light
2. There are fixed ECU errors in memory: P0113, P1188, P1185
3. Resetting errors, then starting the engine causing them to reappear
4. The temperature sensor transmits the correct information (20 С), lambdas (new, intermotor) - give out the correction (0.3-1.25V).
But my BECM Power unit - fried, Fuse 10, Fuse 17 - errors at console.
Can my problem (ECU errors) be associated with BECM?
Any ideas?
Thank you
