Do not purchase EBC rotors or pads for your Land Rover. I equipped my 2004 Range Rover with EBC green stuff pads and slotted/dimpled rotors front and rear. I did some research beforehand with mixed results. I assumed that if Atlantic British offered them as premium equipment that I could trust their opinion, but that was a terribly wrong assumption. EBC greenstuff pads are the worst pads I have ever put on a vehicle, period, and I have used many different pads and rotors on over one hundred. The pads are opposite of everything they are advertised to be! They are very dusty (dark brown and hard to get off wheels even with wheel cleaner), squeaked for first 2 months, were over half worn after less than 3000 miles, and scoured or left material on the rotors that caused SIGNIFICANT pulsation. I thought the EBC rotors were bad with only a few thousand miles so I replaced them with a different brand (Centric drilled). The same pulsating symptoms returned so I switched out the pads for Akebono ceramic pads, turned the rotors, and now life is grand. Akebono euro ceramic pads produce virtually NO dust, it is amazing. They last very long and the wear on the rotors is even and minimal. The only downside to the Akebono pads is I feel they provide slightly less powerful breaking than the LR original equipment pads. Please trust in my experience and do not go through the same and expensive situation.
