Ok, so this problem started after the first head gasket replacement. Upon breaking down the engine (@114,000 miles), my buddy mechanic (an off shift LR tech) noticed how some tappets/lifters had square wear marks (signs of needing replaced according to RAVE) and my camshaft was also worn a bit, nothing excessive but about right for 114K miles. So I was convinced to replace the camshaft, tappets/lifters and while I was at it, the timing chain, along with all the typical head gasket related materials. All parts were ordered through Atlantic British. Everything seemed fine and the truck ran well, until about 1200 miles later. Excessive misfiring (cylinder 6) and very loud rattling of the lifters was noticed, along with a backfire noise through the airbox. I never overheated the engine, but I did have to limp it 20 miles to a buddy's house since I was in rural area.
After getting the truck towed to an actual rover shop this time, so the work could be warrantied, it was discovered that the backfire through the airbox was due to the exhaust valve not opening, therefore the cylinder combustion was backfiring through the inlet valve. This was due to the fact that the #6 cylinder camshaft lobe was completely gone. It had been completely ground down to the shaft. So there was nothing to open the exhaust valve. It was believed that the lifter had seized and basically beat the lobe down to nothing. So now the top end of the engine was completely redone again, new camshaft, new lifters, all the appropriate head gaskets etc..., new plugs, and even a new water pump just because.
So now after the second rebuild, everything seemed fine. We drove to the Outer Banks,NC on vacation, and had been driving it to work for almost 2 months.
Now approx. 2000 miles later, I had another misfire and that all too familiar sickening sound of lifters rattling. I immediately took the truck to the shop. After getting a phone call back this afternoon, it seems the exact same thing has happened, except this time the problem is with cylinder #2. WTF? I mean if it was the same #6 cylinder it would make a bit more sense, but since now the camshaft lobe is completely gone on cylinder 2, I'm completely confused.
When the shop did all the work last time, they checked all of the valves, and pushrods and everything seemed in order. The shop is confused as well. That's two camshafts my engine has eaten is less than 4K miles.
So this thread is asking for everyone's help in figuring out what in the hell is going on? Please just give me any possible causes or solutions to this problem!!
