Have an issue with the height selector switch for eas in automatic mode it works perfectly, but when you select motorway setting it will drop to access mode even with the inhibit switch on!
Have any of you good people got any ideas, thanks.
1995-2002 Range Rover Classic
check your heights, also motorway is not user selectable. off road, city and access are selectable. motorway is automatic once above 50mph for over 3 minutes
Motorway IS user selectable, but only with the inhibit switch activated. Which leads me to suspect the inhibit switch. With it activated, will the Range lower to motorway height when doing over 50mph for a minute or so? It should do so only with the inhibit switch inactive. Maybe the signal isn't getting through to the EAS. Does the light work?
All the lights on the switch work, or do you mean the inhibit switch. will try your idea tomorrow on the way to work!
Tried the height selector switch today,and guess what it all works again as it should.
Starting to think none of the functions on this car were not used much during it's lifetime. maybe see if I can get some contact cleaner in the switches!
