Can anyone please explain which solenoid and valve on the valve block operates which wheel?
(And which airline goes to which wheel (numbered 1,2,3,4 at the valve block)?
I have rebuilt my valve block thrice and it leaks down on a different wheel each time - first front right, then both front, now left rear - if I could figure out how to isolate that valve and solenoid I could be more precise in my repairs instead of replacing everything and then getting a different fault.
Sorry if this has been posted before but I can't find the answer despite searching through the forums.
Thanks.
Discussion Starter #2
Oh, and why are there 7 valves and only 4 wheels? I know one of them controls ingress and egress of air from the compressor but the others??? Help?
FOUNDING MEMBER
I can never remember the numbers, (one of these days I'll memorize them..)
On the top, from the front heading back they are:
Exhaust
Inlet
Right Front
Left Rear
Diaphragm actuator
on bottom, front to rear:
Left Front
Right Rear
Thank you very much!
Exhaust
Inlet
Right Front
Left Rear
Diaphragm actuator
Left Front
Right Rear
